oven to do blackhousing??
so i seen couple of my brothers friend oven their headlight to get on the inside of it. I wanna spray my turn signal amber and do blackhousing. Anyone got some tips or wat temperature and how long i should leave it in for? A step by step process would be nice.
Make sure you put the headlights on a flat pan and have non of the weaker clear plastic touching the pan. I hear putting the light on a wet towel of cardboard can help from melting the plastic all over your oven. Once you heated it enough make sure you have a friend pry open the lights as the sealent hardens very quickly. When putting back together heat the light again so the sealent is soft then press the light back together use zip ties to hold in pressed in. After its done and dry apply new sealent to be on the safe said. Have fun.
trooper0641
Mar 2, 2005 04:36 PM
animated_life
Dec 27, 2003 12:03 PM
