Lighting HID/Xenon kits, Retrofits and Associated Topics
O-NEX HID kit help
Old Jun 6, 2008 | 04:11 PM
Dr. GSR's Avatar
New User
Default O-NEX HID kit help
has anyone installed the O-NEX HID kit on an EK??
I know it deletes the use of the brights, but I can't get it to work.
any tricks or weird wiring needed?
Old Jun 6, 2008 | 05:01 PM
batallic's Avatar
isnt it plug and play, using stock headlight harness
Old Jun 7, 2008 | 05:45 PM
operatic's Avatar
Default Re: O-NEX HID kit help (Dr. GSR)
I've never installed an O-NEX HID kit but I would imagine that if it is not turning on, try to turn on your high beams. If that does not work run through the following.
Is the plug that connects your ballast to your OEM connector plugged in correctly?
Plugs from the ballast to bulbs connected properly?
Check to see if the fuses are still good.
Those are some good start points.
mikeaitken
Lighting
Feb 4, 2008 12:11 PM
spotscivic
21
May 16, 2007 05:13 AM
GQ 05YellowEVO8
Feb 9, 2002 07:19 AM
