Lighting HID/Xenon kits, Retrofits and Associated Topics
Least invasive way to turn on LEDs when door opens? (no toggle switch)
Old May 18, 2016 | 12:20 AM
Adam V's Avatar
Default Least invasive way to turn on LEDs when door opens? (no toggle switch)
Going to install some red LED strips into the footwells of my red 1994 Honda Accord LX Sedan. I was thinking of either tying in to either the dome light or the door lights. The dome light might be easier, but I normally have the dome set to OFF anyway, so if possible, I'd like to either run off the door light's wires or perhaps there's a fuse I can hook into that activates with the door lights, preferably internally (instead of under the hood, which would have to run much farther in that case). I want these to run only when the door is opened, obviously. I don't need red lighting during my entire drive.
I looked up fuse diagrams but what I found didn't provide sufficient information.
Old May 18, 2016 | 05:23 AM
tony_2018's Avatar
Fish Twig
Default Re: Least invasive way to turn on LEDs when door opens? (no toggle switch)
Need to locate a 5v power source and tap into the door trigger, done.
Old May 18, 2016 | 09:09 AM
Adam V's Avatar
You make it sound easy but that is far from enough information for someone as unskilled as me.
This is the first car I've ever tinkered with. I've only ever changed my own oil, replaced the o2 sensor, and installed a sound system. This is my first time doing anything with lights aside from replacing burnt out bulbs.
crazyhorse2011
Aug 11, 2016 09:51 AM
deving916
Nov 19, 2013 12:43 PM
bama*pilot
Aug 28, 2011 09:51 AM
taney
Honda Civic (2006 - 2015)
Jan 19, 2007 10:11 PM
5 Liter Eater
Jan 25, 2002 05:32 AM
