Lighting HID/Xenon kits, Retrofits and Associated Topics
K2 Motor Projection Headlights
Old May 7, 2009 | 11:46 AM
SOHC_civic_si's Avatar
Default K2 Motor Projection Headlights
http://www.k2motor.com/2lhp-cv99jm-tm.html
Has anybody used these before? I am looking for some feedback. I am looking for a brighter set of headlights. Exactly how much brighter is projection compared to stock. I was thinking about HID's, but the good kit's look expensive and I don't think these look too bad. Thanks
Old May 7, 2009 | 09:47 PM
djslim23's Avatar
Default Re: K2 Motor Projection Headlights
Don't get those. They fall under the category of eBay projector headlights, which have shitty output. OEM halogen projectors are significantly better than OEM reflectors, and OEM HID projectors are insanely better than OEM halogen projectors. It's worth the dough, save up and don't skimp cause you'll regret it when you realize you want to do a retrofit. That happened to me! Could have saved a hundred bucks or so if I just saved some $$$ to do the retrofit.
Old May 9, 2009 | 02:05 PM
98civdx's Avatar
Master Detailer
thoses look like expensive ebay sh*t to me.
but people that have used ebay lights like that normally have OK results not great.
but you will have a little better results with thoses with a pnp kit then stockers.
but i DO NOT reccomend a pnp kit but if your going to use them projectors are better the reflectors.
Joeytheman
Lighting
Dec 12, 2011 09:35 AM
lduque
Honda Civic (2001 - 2005)
10
Aug 24, 2007 08:01 AM
stuie08
Jan 27, 2007 08:05 PM
RedGSR
Jun 6, 2004 09:39 PM
MestizoRacer310
Jul 17, 2003 12:43 AM
