Lighting HID/Xenon kits, Retrofits and Associated Topics
Interior lights dim with headlights on and engine off, help?
Old Dec 25, 2015 | 07:08 AM
lancercool's Avatar
Default Interior lights dim with headlights on and engine off, help?
I just finished an engine swap and got a few small problems, was hoping honda tech could help me with them.
The dash and climate control light goes really dim when I turn on my headlights, to the degree where you hardly know they're on. However the clock doesn't dim at all. A lot of people say it's the alternator, but I did this with the engine off, could it still be the alternator? Fuses are fine.
Other problem I believe doesn't belong to this section but i Figured should ask anyway, the tachometer doesn't work. Car is 97 ls, engine is jdm B18C and ecu is chipped p28, everything else seems ok except for the tachometer, I switched to a P73 the tachometer still doesn't work. I'm about to get a new distributor and try but is there anything else I should check?
Thanks Honda Tech.
Meggles
Honda CR-V & Element
Nov 19, 2024 12:34 PM
lancercool
Dec 25, 2015 07:07 PM
beefisforbadbwo
Honda Civic (2001 - 2005)
Dec 27, 2013 03:08 PM
RollTide
Aug 6, 2012 01:27 PM
romeo_f
Apr 19, 2011 11:26 AM
