Lighting HID/Xenon kits, Retrofits and Associated Topics
Integra JDM headlight
Old Mar 26, 2008 | 08:30 AM
kweezerkwee's Avatar
Default Integra JDM headlight
i answered my own question already so now i want to know how do i change the fog light light bulbs? one of my light is brighter than the other does that mean one of them is dieing? be great if you guys can tell me the bulb size too. Thanks
Modified by kweezerkwee at 7:20 PM 3/26/2008
Old Mar 26, 2008 | 08:32 PM
Meoshe's Avatar
What year integra?
Old Mar 26, 2008 | 08:54 PM
Sumslapper's Avatar
Year 3030
Default Re: (Meoshe)
if its 96+ for the jdm front there is the triangle piece on top of the headlights with 3 screws in it. take that off and the bulb is in there.
Old Mar 26, 2008 | 08:58 PM
Meoshe's Avatar
FYI the DA one pice headlight is the same basically. Uses an H3 35 watt bulb. not sure about the 96.
Old Mar 28, 2008 | 12:10 AM
cm8719500's Avatar
Default Re: (Sumslapper)
Have you guys ever heard of any one replacing the yellow bulb for the fogs on a DC2 JDM head lights, cause mine is broken but even after taking that traingle piece on the top part of the head light I still cant get to it..................
If any one know haws to do this I would appreceate some help.............
Thanks
Old Mar 29, 2008 | 01:42 PM
Sumslapper's Avatar
Year 3030
Default Re: (cm8719500)
if the actual yellow lense is broken the only way to get it out is if you take the actual lense off of the headlight and replace it or buy a new headlight. Cheaper alternative would to just buy a yellow fog light.
Old Mar 29, 2008 | 06:51 PM
Meoshe's Avatar
I thought they were inserts like the legends.
Old Mar 29, 2008 | 07:54 PM
EGcelent's Avatar
Yep they are
Old Apr 2, 2008 | 11:34 PM
okay so i got all my bulbs replaced and it seem like i have to clean the inside but i don't want to do that already had bad experience. I have another question though where is the screw located to adjust my cut off point
Old Apr 5, 2008 | 09:10 PM
marine0621usmc's Avatar
i have that same problem. the only way i took it out was to drill a big hole on the back to unscrew the yellow lense out. but i havent found the foglight capsules the replace it. let me know if you find some.
UNBRE4K4BLE
Honda Civic (2001 - 2005)
Sep 3, 2007 05:06 PM
tony456
May 12, 2005 02:03 PM
asianic415
Feb 7, 2004 09:36 PM
fangtl
Sep 14, 2001 07:26 AM
