Lighting HID/Xenon kits, Retrofits and Associated Topics
HVAC lights
Old Jan 5, 2008 | 09:19 AM
citystreetsbimmer's Avatar
Default HVAC lights
hows it going ppl. i noticed in my 1992 hatch that the back lighting on the heater/ac control seems to light up half only on one side (closest to driver) and a couple times not light up at all. im assumning there is bulbs in there i can change?anyone know a removale step for this?thanks
Old Jan 5, 2008 | 10:24 PM
Default Re: HVAC lights (citystreetsbimmer)
anyone?
Old Jan 9, 2008 | 10:18 PM
anyone ever remove there heater control from a 92 hatch civic?
Old Jan 13, 2008 | 11:11 PM
White95SiHB's Avatar
yes, and it's a pain the *** if you do it for the first time. A lot of curse words will come right out of your mouth.
Since you said it lights up on one side but will be sometimes on or sometimes off, then I think the problem is not with the bulb itself but with the silicon circuit board. I changed the bulbs in my hatchback and it still does the same thing. I have to bang on the dash to turn it on, or sometimes road vibrations or switching on the fans will turn it off. I took apart the climate control unit but the solder points look fine and the wires look fine, I tried wiggling the wires when it was connected but nothing happens unless I jiggle the whole thing. The frustration made me utter just about every curse word known to me.
By the way, check this thread out, that's the thread I referred to while trying to figure out how to take the climate control out.
https://honda-tech.com/zerothread?id=661308
Old Jan 14, 2008 | 07:53 AM
Default Re: HVAC lights (White95SiHB)
excellent info . thank you
Old Jan 14, 2008 | 12:44 PM
suno's Avatar
Sometime its the switch thats bad.
MR Rodgers
Honda Civic (2006 - 2015)
Aug 7, 2018 04:06 PM
aznlaoboi315
Feb 17, 2008 08:43 PM
tapuout
12
May 8, 2006 12:16 PM
remo
Jan 15, 2005 02:16 PM
