Lighting HID/Xenon kits, Retrofits and Associated Topics
How to remove headlight fluting?
Old Nov 12, 2007 | 08:58 AM
inh's Avatar
inh
Default How to remove headlight fluting?
I really want a set of HIDs retrofitted in to my CRX headlights, but I'm going to be putting the JDM front end on, with EDM lights. I'm not aware of anyone that makes aftermarket headlights that fit the JDM front end, so I guess my only option is to remove the fluting in the headlight glass...
Anyone know how? Or where to pick up some aftermarket 'projector' headlights with a smooth front piece that will fit?
Old Nov 12, 2007 | 09:30 AM
bpr0422's Avatar
Default Re: How to remove headlight fluting? (inh)
i've heard ppl grinding it down..
or you can make your own lens, some plexiglass, plaster, oven, and some wooden contraption... i saw how to do it on hidplanet..forget the link tho...
Old Nov 12, 2007 | 10:14 AM
inh's Avatar
inh
Searched for a few different terms, no luck =[
Old Nov 12, 2007 | 10:55 AM
Padawan's Avatar
Darth ModerVader
If they're plastic, you can sand and polish the lens to remove the fluting. Believe it or not though, if you're installing HID projectors behind the lens it really won't interfere very much with the output, even if you leave the fluting intact.
Old Nov 12, 2007 | 11:03 AM
inh's Avatar
inh
I figured the fluting would scatter the beam... Might be worth looking in to..
And they arent plastic, sadly.. Geniune glass EDM ones..
Old Nov 12, 2007 | 11:15 AM
Padawan's Avatar
Darth ModerVader
Default Re: (inh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inh &raquo;</TD></TR><TR><TD CLASS="quote">I figured the fluting would scatter the beam... </TD></TR></TABLE>
The effect is minimal, mainly because the beam from the projectors is so tightly focused.
Old Nov 12, 2007 | 11:43 AM
inh's Avatar
inh
Good to know =] I suppose I could just get the retrofit done, and if there are any severe issues just make some clear front pieces out of plexi like suggested above =]
JTN416
Jun 12, 2012 06:50 PM
tArebelpinoy
Sep 3, 2008 06:06 PM
JDMStilez
Dec 27, 2004 12:07 AM
E-lude78
Mar 22, 2004 04:10 AM
Accordhspec
Sep 18, 2003 05:06 AM
