Lighting HID/Xenon kits, Retrofits and Associated Topics
HIDs In My 98 Civic
Old Sep 21, 2007 | 05:16 PM
n8dizzel's Avatar
Default HIDs In My 98 Civic
I just put a HID kit into my 98 civic. It looks gr8. I cant help but feel that the light output tho is not up to par with some of the newer cars i see with the HID lights. The lenses are crystal clear. I'm thinking about removing the diffuser in the lens. Has anyone else tried this? I have a old set of headlights and i removed the diffuser and tonight I'm going to hook one of my lights to it and compare it to the diffused light. Just to clarify, the diffuser is the piece of metal that surrounds the light bulb to deflect the light back to the silver surface and out the plastic lens.
Old Sep 21, 2007 | 05:17 PM
JSPECSIR's Avatar
Default Re: HIDs In My 98 Civic (n8dizzel)
put on you flamesuit!
Old Sep 21, 2007 | 06:19 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n8dizzel &raquo;</TD></TR><TR><TD CLASS="quote">I just put a HID kit into my 98 civic. It looks gr8. I cant help but feel that the light output tho is not up to par with some of the newer cars i see with the HID lights.</TD></TR></TABLE>
It's not "up to par" because the cars you see are using actual purpose-built HID headlamps, not halogen headlamps with an HID kit, and the Civic headlamps are rather poor to begin with. Removing the shield in the housings will only result in increased glare for other drivers. It's not a good idea.
Old Sep 22, 2007 | 11:46 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: HIDs In My 98 Civic (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
It's not "up to par" because the cars you see are using actual purpose-built HID headlamps, not halogen headlamps with an HID kit, and the Civic headlamps are rather poor to begin with. Removing the shield in the housings will only result in increased glare for other drivers. It's not a good idea. </TD></TR></TABLE>
X2.
You can retrofit different projectors into your civics headlights and have an awesome projection. Just search "HID retrofit" and you'll get plenty of results
Old Sep 25, 2007 | 05:36 AM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n8dizzel &raquo;</TD></TR><TR><TD CLASS="quote"> I'm thinking about removing the diffuser in the lens. </TD></TR></TABLE>
As if the HID kit isn't blinding enough.
http://www.customlightz.com/?p...l-sol
Educate yourself
Old Sep 25, 2007 | 02:34 PM
n8dizzel's Avatar
Default Re: HIDs In My 98 Civic (-Bionic-)
i readjusted the beam as to be considerate to my fellow drivers. they are no less blinding than a stock hid setup. just gotta keep up with the times. i decided not to remove the diffuser after seeing the results with the spare i had.
Old Sep 25, 2007 | 09:21 PM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n8dizzel &raquo;</TD></TR><TR><TD CLASS="quote">i readjusted the beam as to be considerate to my fellow drivers. they are no less blinding than a stock hid setup. just gotta keep up with the times. </TD></TR></TABLE>
Don't kid yourself
Old Oct 2, 2007 | 04:24 AM
CincinnatiBB6's Avatar
get a retro-fit
Old Oct 15, 2007 | 06:15 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: (CincinnatiBB6)
Old Oct 19, 2007 | 06:20 PM
Rayz_Si's Avatar
From: Land of the Hillbillies and Shotguns, Ontario, Canada
Your hid bulbs come with a glare sheild ( the thing you are calling a difuser) to project the light beam straight forward instead of bouncing downwards, then up in to drivers eyes like a high beam path.
BTW what k are you running? I am running 8000k in my 96 coupe, nobody has complained about being blinded passing, or criusing behind me there just not as bright as factory 4300k systems, but much brighter then stock halogens by far. I'm happy with my HIDs
Old Oct 21, 2007 | 08:57 AM
EK_B's Avatar
People will be pissed driving pass by you. And as mentioned, run 4300k for the most output if you are not already.
Old Oct 24, 2007 | 02:07 AM
DOHCturbo02's Avatar
96-00 Civic headlight isn't designed correctly to distribute HID lighting! Do yourself and all the other drivers around you a favor and look into doing a retrofit to your stock civic headlights. You will be amazed by the light output and will truly be able to enjoy the benefits of an HID kit on your civic, not to mention you won't have on coming traffic high beam you Good luck
Old Oct 24, 2007 | 03:38 PM
MeIpk3's Avatar
PNP kits suck. Do it the right way.
onoitsaldrin
Paint and Body
12
Oct 2, 2008 08:41 AM
EJ8 GSR-T
Dec 25, 2006 09:34 PM
CiViC Si OD
Apr 29, 2006 07:31 PM
lewd43
Audio / Security / Video
Sep 30, 2004 10:53 AM
hobo79
Jan 16, 2004 09:23 PM
