Lighting HID/Xenon kits, Retrofits and Associated Topics
help with wiring leds
Old Nov 18, 2011 | 08:38 PM
germanturtle's Avatar
Default help with wiring leds
i am trying to figure out what wires are positive and which are negative.its a factory plug with four wires feeding it.im pretty sure it had a set of two lights on the end (license plate lights) i am installing two leds in the plate bolt holes instead. leds have a red and black wire. they need to turn on when the lights are on. i have an ohmeter/voltmeter. any help will be appreciated i will gladly post pics of the plug if necessary. i will remove the plug and ideally have the ability to plug my leds directly into the factory harness.
Old Nov 19, 2011 | 12:15 AM
CivicSD's Avatar
Default Re: help with wiring leds
factory service manual wiring schematics could tell you what all 4 wires do
Old Nov 19, 2011 | 08:33 PM
Blazin Si's Avatar
Loved
Community Favorite
Have you tried the DMM? It will tell you which is positive and which is negative.
tysonzane
Mar 1, 2012 11:00 PM
503_EF9
May 21, 2007 10:50 PM
professorman
Mar 18, 2007 08:03 AM
iheartamy
Dec 23, 2006 08:43 AM
DelSol808
Nov 2, 2002 10:42 PM
