Lighting HID/Xenon kits, Retrofits and Associated Topics
Help/Question about fixing EG Headlamp
Old Jun 7, 2012 | 06:19 AM
preetyboi06's Avatar
Default Help/Question about fixing EG Headlamp
Whats good HT I have a question and need help if this is even possible. I have OEM Eg headlamps that are in mint coniditon the only problem is that one tab (the tab in which you screw the corner light into that hold the corner to the headlmap so it sits flush) is broken. Is there anything that I can do to fix this? Thanks for you help and I will post pics if needed.
Old Jun 7, 2012 | 07:15 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: Help/Question about fixing EG Headlamp
I would just go to a junkyard and get another one or you could epoxy some form of new tab if you wanted to go Macgyver on it!
Old Jun 7, 2012 | 10:31 AM
TunerN00b's Avatar
Any good 2 part epoxy will fix it. Plastic welding would work too, but is going to be more effort.
But, um, you can't call a damaged part "mint". Mint has a meaning, and broken is not part of it.
Old Jun 18, 2012 | 04:39 AM
Thanks for your help. Ended up just getting new headlights. And @TunnerN00b your right about the whole "mint" thing. I apologize.
mfisher1987
Suspension & Brakes
Jan 8, 2012 05:01 PM
civicVI
Jul 27, 2006 08:14 AM
