Lighting HID/Xenon kits, Retrofits and Associated Topics
head lights for jdm itr headlights
Old Oct 9, 2007 | 12:02 PM
mart182003's Avatar
Default head lights for jdm itr headlights
does anybody know what size bulbs do the jdm itr headlights use cause i want to convert to hid but i dont know size. thanks
Old Oct 9, 2007 | 12:18 PM
Jo3f1sh's Avatar
Default Re: head lights for jdm itr headlights (mart182003)
Should be the same as US Spec. 9006 for the low beam projector.
Old Oct 9, 2007 | 12:21 PM
I AM WEASEL's Avatar
the hid headlight takes either a d2s or a d2r bulb, but if you are trying to turn your non hid's into hid's you should retrofit some hid projectors into your housing.
Old Oct 9, 2007 | 12:24 PM
Jo3f1sh's Avatar
Default Re: (JDM se-R)
I assumed he was installing a kit into non HID housings since he said he was converting. Retrofitting is always the best way to go and produces the best results (no glare, proper light pattern, etc.)
Old Oct 9, 2007 | 12:30 PM
Rikter's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM se-R &raquo;</TD></TR><TR><TD CLASS="quote">the hid headlight takes either a d2s or a d2r bulb, but if you are trying to turn your non hid's into hid's you should retrofit some hid projectors into your housing.</TD></TR></TABLE>
Uhhh.. every hid bulb is d2r or d2s. D2R bulbs are shielded while D2S bulbs are not. I would recommend you get the D2R style bulbs to cut down on the reflected glare as much as possible. Those are just types of bulbs. Now you need to know what style and I think he is correct with 9006 but someone who has it'll tell you for sure.
-Rik
Old Oct 9, 2007 | 12:34 PM
Default Re: (Rikter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rikter &raquo;</TD></TR><TR><TD CLASS="quote">
-Rik</TD></TR></TABLE>
http://optionsauto.com/departments.asp?dept=54 follow the link and it will show you that there is a difference between the d2r, d2s, and 9006 bulbs. d2r and d2s might be every hid bulb but a 9006 bulb is not an hid bulb.
Modified by JDM se-R at 1:45 PM 10/9/2007
Old Oct 9, 2007 | 12:35 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rikter &raquo;</TD></TR><TR><TD CLASS="quote">Uhhh.. every hid bulb is d2r or d2s.</TD></TR></TABLE>
Most, but not every.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rikter &raquo;</TD></TR><TR><TD CLASS="quote">I would recommend you get the D2R style bulbs to cut down on the reflected glare as much as possible.</TD></TR></TABLE>
The D2R is intended for reflector housing usage, and really won't help improve the beam pattern when used in a halogen projector housing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rikter &raquo;</TD></TR><TR><TD CLASS="quote"> I think he is correct with 9006 but someone who has it'll tell you for sure.</TD></TR></TABLE>
9006 is correct.
gtrwerks
Jul 1, 2009 05:08 PM
pizzle
Feb 22, 2007 10:29 PM
Monkey Z.
Feb 2, 2005 06:55 AM
an2ny888
Dec 9, 2003 07:32 PM
ILOVEGIRLS
Feb 8, 2003 07:31 PM
