Lighting HID/Xenon kits, Retrofits and Associated Topics
H.I.D projectors
Old Feb 29, 2012 | 06:10 PM
jdmmatters's Avatar
Default H.I.D projectors
Is there anyone who makes projector headlights for an 86 civic 4 door i have H.I.Ds in but they dont look as good as some friends with projectors any help would be cool
Old Feb 29, 2012 | 07:04 PM
Joon Joon's Avatar
Default Re: H.I.D projectors
they have premade projector headlights which arent meant for hids.. if you want the best output then do a retrofit..
Old Mar 4, 2012 | 08:31 AM
prelude1897's Avatar
Could purchase some cheap eBay projector lights and then swap out the shitty projectors for some true HID projectors or if there's aftermarket OE lights, could purchase those and retrofit them, cause usually aftermarket lights come with plastic headlight lenses instead of glass which would be better
Old Mar 8, 2012 | 07:45 PM
Sleward's Avatar
Depends, you want non fluted headlights, of which a majority are plastic.
The fluted ones aren't meant for H.I.D's.
Old Mar 12, 2012 | 06:06 PM
cdscowboy's Avatar
Yeah you wanna make sure you get the clear glass lenses. The heat from a true HID setup will discolor (and possibly melt) the plastic lenses.
I've been looking for aftermarket housings for the '86 CRX style, and so far I haven't seen any.
Old Mar 12, 2012 | 07:13 PM
Joon Joon's Avatar
glass will actually distort the color a little bit.. clear plastic would be best.. the clear glass is fine also..
Old Mar 14, 2012 | 02:40 PM
TunerN00b's Avatar
At 35W and greater efficiency, HID setups produce a lot less heat than the 55W halogen bulbs they replace.
michael-crxsi
24
Jun 18, 2010 06:45 PM
turboman
Lighting
11
Jul 14, 2008 08:07 AM
got_speed
Oct 24, 2007 04:36 AM
emortal
Oct 28, 2001 08:34 PM
