Lighting HID/Xenon kits, Retrofits and Associated Topics
Fog light problem
Old Feb 28, 2009 | 08:30 AM
92eg_h22's Avatar
Default Fog light problem
So i have just purchased an ebay set of fog lights and i hooked everything up properly(searched a million times on HT) and for some reason the fuse is melting and the relay has a wire coming out of it that i guess is the positive for the actual fogs that keeps melting to the first fog light.(blue on my harness) Fogs barely worked then turned off cuz they started melting. I thought it was a bad connection at the battery. when i changed where the wire coming from the fuse attached to the battery i was able to get them to work without melting.
Started the car today and checked the lights and nothing was wrong. they worked fine. Soon as i get to the end of my street i smell it burning and the fog lights went off. Fuse never blew just melted. what is goin on? I know they work fine but for some reason its doin this? any help...i hate electricity
Old Feb 28, 2009 | 09:26 AM
92eg_h22's Avatar
Default Re: Fog light problem
the wire coming from the battery to the fuse is not the one getting hot or melting....the fuse and the blue power wire from the relay are the only thing melting. The burning doesnt go past the first fog light on the harness. I know they both worked fine for a minute and i checked the relay when the lights were working and nothing was hot or burning or anything.....then boom, they go out this morning and melt bad...WTF???
Old Mar 1, 2009 | 03:11 PM
brutekiller787's Avatar
what amperage is your fuse. try lowering that it might be too high
Old Mar 1, 2009 | 04:49 PM
92eg_h22's Avatar
it came with a 30 amp...i thought 15 would have been more appropriate but like i said, i hate electricity!
Old Mar 1, 2009 | 04:58 PM
ballin_tha_ef's Avatar
I had the same problem with my fogs......getting a new harness send out...I hope it doesn't happen again. where did you hook up the yellow wire that comes from the oem style switch to
Old Mar 5, 2009 | 11:16 AM
92eg_h22's Avatar
i had a blue(ground) red(power to fogs) and 2 blacks (power from fuse box)
awdgsx96
Dec 27, 2009 09:23 AM
ScottEK
Audio / Security / Video
Jul 24, 2003 08:59 PM
neoburi
13
May 24, 2003 10:44 PM
FUP23
11
Nov 2, 2001 03:35 AM
