Lighting HID/Xenon kits, Retrofits and Associated Topics
dim head lights/high beams?
Old Oct 23, 2007 | 02:15 PM
sonny0330's Avatar
Default dim head lights/high beams?
is there any way to dim the headlights or high beams?
Old Oct 23, 2007 | 03:12 PM
Padawan's Avatar
Darth ModerVader
Default Re: dim head lights/high beams? (sonny0330)
What do you mean by dim?
Old Oct 23, 2007 | 07:28 PM
sonny0330's Avatar
Default Re: dim head lights/high beams? (Padawan)
i have a 94 teg and i want to drive with the hi beams on but i dont want to blind people. so is there any way to make the high beams less bright
Old Oct 23, 2007 | 07:55 PM
Padawan's Avatar
Darth ModerVader
If you just want the high beams to appear lit, you can install city lights in them.
Old Oct 24, 2007 | 01:07 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I think some daytime running light kits will step down the voltage to the high beams to make them run dimmer than normal.
Old Oct 24, 2007 | 03:44 PM
sonny0330's Avatar
thanks but the city light isnt they bright huh?
Old Oct 24, 2007 | 04:08 PM
Padawan's Avatar
Darth ModerVader
Default Re: (sonny0330)
City lights use a 5 watt bulb, so they are not very bright. They're basically equivalent to our parking lights.
Old Oct 24, 2007 | 09:37 PM
sonny0330's Avatar
alright thanks so thats the only way? is there any way i could put like a reflector in it so it wont be as bright?
Old Oct 25, 2007 | 03:31 AM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sonny0330 &raquo;</TD></TR><TR><TD CLASS="quote">alright thanks so thats the only way? is there any way i could put like a reflector in it so it wont be as bright?</TD></TR></TABLE>
What is your purpose for doing this? As I said, some DRL kits will dim the actual high beam bulb, and they will be on all the time while driving if you have the headlights off.
Old Oct 25, 2007 | 10:45 AM
sonny0330's Avatar
my purpose is to jus having them all the time. where could i get the drl kit?
Old Oct 25, 2007 | 11:13 AM
Relic1's Avatar
if you check the wiring schematic of alot of GM cars, they run the two high beams in series to produce the twinkly DRL lighting.
not a difficult thing to create with a couple relays and diodes.
Old Oct 25, 2007 | 02:28 PM
omg_miiiike's Avatar
Default Re: (Relic1)
Sounds like someones trying to hard .
Old Oct 25, 2007 | 02:51 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sonny0330 &raquo;</TD></TR><TR><TD CLASS="quote">my purpose is to jus having them all the time. where could i get the drl kit?</TD></TR></TABLE>
http://www.daytime-running-lights.com
Old Oct 25, 2007 | 03:50 PM
smileyyello's Avatar
your problem is quite difficult... anyways..i just want to ask why do you like to dim the headlights?
bmaya
Honda Civic (2006 - 2015)
18
Mar 6, 2009 05:16 AM
xxnickpxx
Dec 26, 2007 12:43 PM
mario_pic
Dec 18, 2007 04:14 PM
zachkiro
Honda Civic (2001 - 2005)
Oct 4, 2007 03:16 AM
Speedraca01
Jan 19, 2006 07:47 PM
