Civic headlight wiering.
alright guys, so my high beams work but the low beams wont, i checked the fuse to see if that was the problem but it is not. I dont know how to check the wiering because i have no idea what to look for. Is this something that i should take to the honda dealer?
Dude if you had a mad tyte JDM yo parking pole and a tow your high beams would work fo sho!!
But seriously, replace a bulb with a know working H4 bulb. A ground would not be the issue as both high and low beams share a common ground.
If after swapping a bulb with a known working bulb test your combination switch on the steering column. If you're not a douche, I have a DIY for that too.
mrbassman001
Jan 7, 2011 10:22 AM
GraphiteMW
Jun 26, 2008 04:12 PM
graywzc
Oct 13, 2007 05:55 PM
gen5accstilez
Honda Civic (2001 - 2005)
Sep 3, 2007 08:13 PM
Jacen
Mar 22, 2006 10:51 PM
