Lighting HID/Xenon kits, Retrofits and Associated Topics
which Bulb is better
Old Jan 4, 2008 | 01:48 AM
16v's Avatar
16v
Default Luminics VS Nokya
which one you recommend
Old Jan 4, 2008 | 04:28 AM
JKov240's Avatar
Default Re: Luminics VS Nokya (16v)
The "Lighting" section...just a little bit down on the main page
Old Jan 4, 2008 | 07:11 AM
Padawan's Avatar
Darth ModerVader
Neither of them is a particularly great choice. What criteria are you using to judge them, and what are you hoping to achieve?
Old Jan 6, 2008 | 07:42 AM
hometheaterman's Avatar
Default Re: Luminics VS Nokya (Padawan)
I"ve never used Luminics but am going to have to give Nokya a
The first set of Nokya's I had for a few days. They were the Arctic white ones and I really liked the color to them but found that it was really hard to see with them so I took them back to the store I got them from. I can't comment much more on these other than they had horrible light output when used in my truck.
The next set I bought and still have as I bought them off eBay was a set of Arctic Purples for my Accord when my Eurolite finally burnt out. The light output was okay with these maybe not quite as good as stock but you could see fine. I was really impressed with the color. When looking at them it was a really pinkish purple. It lit everything up on the road purple. I really liked the color output of these and the light output was okay. Here is where I ran into a problem about a week later I noticed the light output wasn't as purple. The were purple for about a week then I guess the coating burnt off or something as they are just pure white now with maybe a slight hint of purple not much though. I'm really dissapointed in the color now. So they are good for about a week maybe not quite that long then I give them a big
I'd check out Farenheit's high wattage bulbs or Eurolite Fusions if you want a blueish bulb thats good. Remember with any high wattage bulb you need to upgrade your wiring and run a risk of melting your housing.
jpm0830
Jan 21, 2013 10:29 PM
B18b Axles
Lighting
Jul 2, 2012 12:28 PM
NOOdS
10
Feb 17, 2009 10:56 AM
hometheaterman
Lighting
14
Dec 3, 2007 03:07 PM
BlKdOutEk
Nov 23, 2005 09:59 PM
