Lighting HID/Xenon kits, Retrofits and Associated Topics
91 integra hid problem??????
Old Jan 12, 2011 | 02:22 PM
4drboostking's Avatar
Icon2 91 integra hid problem??????
alright so heres the deal I have a 91 integra for a winter car that im bored with and want to put some hids on it now a friend of mine gave me some extra ballast he had lying around and I went ahead and orderd some 9004 hid bulbs now when I went to pull out the connector for the stock bulb its huge and my hid kit wont plug into it now I know I have the right bulbs and I did some research online and all the hid kits for this car have the same connectors as what I have no my issue is do you have to replace that huge connector??
here is a pic of the stock connector
[/IMG]
[/IMG]
Old Jan 12, 2011 | 03:38 PM
KILLAB17VTEC's Avatar
Genetically Gay
Default Re: 91 integra hid problem??????
i think the hid plug in to that part.
Old Jan 12, 2011 | 04:03 PM
Hyoriu's Avatar
what kind of HID kit do you have first off? There are many different HID kits out there. Some have harnesses that require you to hook it up to the battery also and some are just direct plug and play. If yours is direct plug and play, you should have one end that will hook up to the socket and another plug coming from the ballast that plugs into 2 wires that come out of the HID bulb.
Old Jan 12, 2011 | 04:57 PM
pghz_last_don91's Avatar
your HID should plug into ur stock connector.
Old Jan 12, 2011 | 05:04 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Don't put HID in 9004 headlights. It will be ALL bad and NOTHING good. 9004 headlight housings are crap anyway, and it'll only be worse with HID.
But to answer the question you need 9004 adapter harnesses.
XskylineX
Lighting
Jun 27, 2010 07:24 AM
94-4door-gsr
Sep 19, 2007 09:39 PM
myronwong
Apr 23, 2006 01:08 AM
