S2000 Oil Pump.
Old Nov 28, 2011 | 05:41 PM
Aesthetic Gains's Avatar
Dos Pupusas
Default S2000 Oil Pump.
What is required to run one of the AP1 oil pumps in a K24A4 block?
Is it better to just run the ERL pump?
Is the K20A2 pump good enough?
What are you guys using?
Thanks.
Old Nov 28, 2011 | 09:48 PM
jdmintegraxsi's Avatar
Default Re: S2000 Oil Pump.
You have to run the ERL setup, a stock s2000 pump wont bolt up right. The normal type s pump should be just fine. You also need the types s tensioner and I think it is the k24 oil pump chain and guide. I don't remember exactly.
I am currently running the ERL s2000 pump and have been for a few seasons now with no problems. It holds 100psi oil pressure to 10,000.
Old Dec 2, 2011 | 11:45 AM
flesh199's Avatar
for a simple build you can run a type-s oil pump.Allmotor street car with a k20a2 oil pump.
Old Dec 3, 2011 | 12:28 PM
Dos Pupusas
I see.
How high are you reving your motor in that video?
Are you using the type s pump?
Old Dec 5, 2011 | 06:36 AM
flesh199's Avatar
Originally Posted by Tonio
I see.
yeah a2 brand new oem pump man.My rev limit is at 8600 on my kpro so we are in the 8900-9000rpm range on the cluster.
s4play
Dec 5, 2011 05:41 PM
Gonzo
Feb 14, 2002 12:57 PM
