problems with ek/k24a2 fuel system
Old Oct 21, 2012 | 05:32 PM
4Door-Ek-Squad's Avatar
Icon2 problems with ek/k24a2 fuel system
ok i have tried looking in the forums n i dont find nething specific on this
i have the stock fuel pump running the k24a2 but it boggs when i step on it, i need more preasure but idk if i can run a stock rsx fuel pump or if i have to buy a walbro 255 or something similar i have 440 injecors, hybrid racing fuel rail n regulator, at idle it reads 40 i read that was ok
if anyone could point me in the right direction with the fuel pump n my k pro is all setup but just can get enough fuel to rlly step on it.....
oh n if anyone now tuning with the krpo it b great to help me out o it im still on learning status im in killeen tx near austin!
Old Oct 21, 2012 | 06:17 PM
doood's Avatar
been there done that
Default Re: problems with ek/k24a2 fuel system
just get the walbro
Old Oct 23, 2012 | 06:43 PM
ok so i went on craigslist n baught a walbro 255 n installed it n everything n when i gunned it, it boggd again, idk if the dude just ripped me off or if i have a seperate prob, he told me he had it in his rsx n he was runnin a k24a2 same as mine he says it run perfect with it oh well but now im trying to diagnose this as a other prob any ideas?????
this is how my motor looks like
Old Oct 23, 2012 | 06:46 PM
Old Oct 23, 2012 | 07:13 PM
SuperChargeEF9's Avatar
U have to get it dyno tune.
Old Oct 23, 2012 | 07:24 PM
how come its not trowing any codes on k pro its tuned alredy to that motor i have the page of when it got tuned on previous owner n i have the load file on my laptop
Old Oct 23, 2012 | 07:25 PM
i was thinking if i can ride the k24a2 on a stock k20a2 fuel pump
Old Oct 23, 2012 | 07:30 PM
it all came off my buddys rsx he had his rsx with that motor n all stuff that i have i just transfered it all to my ek, reason being is that he got rear ended n his rsx was destroid in the rear but all front end was untouched
Old Oct 23, 2012 | 07:34 PM
Haven't know any1 running stock k20a2 pump in a ek, why not just get 255lph walboro.
Dyno tune will fix your problem your having after you install 255.
Old Oct 23, 2012 | 07:35 PM
how much does a dyno tune cost on a guestimation...???
Old Oct 23, 2012 | 07:43 PM
300 for N/A dyno
Old Oct 23, 2012 | 07:45 PM
doood's Avatar
are you running a return on the fuel system?
Old Oct 24, 2012 | 03:55 PM
Yes i am im gona check mao sensors n o2
Map sensor srry
Old Oct 24, 2012 | 09:42 PM
turbociviccoupe's Avatar
Originally Posted by 4Door-Ek-Squad
Map sensor srry
you need a tune... im running 750cc turbocharged on a stock fuel pump. Runs great on a base map I tweaked it through kpro. If you never tuned before Prepare to be amazed by the difference. It dont matter what you got unless you tune to get its full potential. Your car might be bogging out due to being too rich or too lean. you wont know till you put a wideband on it and see where its running in afr. hope this helps. if it was the map it would throw a code right away under boost
Old Oct 25, 2012 | 05:33 AM
I'm doing all motor so do i still need a a/f ratio
I have the kpro but noiudea on how to tune it
Is there a tuning for dummies??? Haha but is there?
Or how can i start tuning cuz i know i can mess things
Up real quick If i don't know what I'm doing
Old Oct 25, 2012 | 09:25 AM
doood's Avatar
playing with kpro without knowing what you're doing is a surefire way to hurt the motor. if you have nobody local to tune you, i recommend an online tune from www.magtuning.com he's tuned me twice with great results.
Old Oct 25, 2012 | 11:56 AM
Oh nice i sure will take a look at that tyvm
Oh n btw my map sensor is good so ama
Start looking at tunes
Old Oct 25, 2012 | 02:57 PM
Hey i took a look n i wanted to ask how does it work
Do i just select street n buy or wat them load it into my
Kpro?
lv6l
Jun 5, 2006 09:33 PM
ares650
Sep 19, 2005 04:31 AM
d16rice
Feb 13, 2005 03:57 PM
Red D Dragon
Apr 3, 2004 06:53 PM
