K24 CRX
Old May 31, 2023 | 06:56 AM
fin781's Avatar
Default K24 CRX
I'm getting ready to pull my gsr and prep this thing for a K24. I've began the agonizing research part and I'm having trouble understanding the mix and matching compatibility of parts. What I mean is for instance, whatever k24 engine I land on, will the transmission wether it's from the 06 RSX or civic SI mate to the block or am I stuck with running an accord trans?
This question reaches out to the wiring harness and header as well and I guess what I'm looking for is a swap guide that is more up to date. I keep finding information from like 2007 and although im sure not a whole lot is changed, some stuff has and easier ways or more resourceful ones have been found. Apologies in advance of this is painful to read but any source to more up to date info would be great. Thanks.
Old May 31, 2023 | 08:30 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: K24 CRX
If you have a K20A/Z or K24A/Z engine, ANY "K" series transmission from a vehicle in which any of the previously mentioned engines come standard will bolt to it. Pay close attention to what the engine mount kit requires for your application... for example, the HASPORT mount kit for a K24 into a 2000-06 Insight requires the use of either an '03-07 Accord 5-Speed or an '04-08 TSX 6-Speed... so anything else doesn't work in the car. In short, remember that just because the transmission bolts to the engine doesn't mean it works in your car.
Wiring is convoluted... there are a LOT of correct answers. It is going to come down to what you want to do and what you want to spend.
TheRookie74
Sep 15, 2015 12:52 PM
JayRay30
Jan 29, 2013 03:33 PM
mattcx
Dec 10, 2012 12:37 AM
unltdacc12
Oct 30, 2002 12:40 PM
