Hey HT, I have a 94 EJ with a k20a2 swap, Type R ECU, and no K-pro (if relevant). I was removing my ECU recently, and after I put it back in I noticed a wire was loose . After looking around I could not find this wires soul mate, so I concluded it may have came off a plug/harness. I searched all my plugs, and I could not find any remnants if where it used to be. I started the car, and everything worked, but on the test drive I noticed the speedo didn't work (It did used to work, and when removing it I remember it went to something). I am unsure of my harness since it came this way. Looks like a "Sparkks" harness but the vendor told me otherwise, as it supposedly looks like a 05-06 harness because I have the jumper for the ECU. I have no clue where this should go, and please bare with me as I am a newb to K-series, and wiring. Could it have been connected to my K-tuned Speed converter ?
Please help me find its home,
Thank you
vvvvvvvvThe Culprit !?!?!vvvvvvvv The yellow wire hanging behind on the harness was hanging I like that I believe. I CAN TAKE MORE PICS IF NEEDED
Maybe I'm tripping out, and it did go to that yellow wire hanging ? Maybe I can see what color is on the other side, and then match it up on a diagram to see if that's the correct wire.
