What is this VTEC? ;)
Old Jun 17, 2013 | 01:45 PM
BlueBandit's Avatar
Default What is this VTEC? ;)
Hey everyone!
I have been more of a rotary nut all my life but after dealing with a money pit of a FD I downgraded to a little track Miata I built.
Sadly that didnt last long as the PO built rebuilt the motor terribly and the head blew within a few months of owning it.
The car was fun to drive but the paint was terrible and I wasnt a fan of rebuilding the 16B motor it had so I switched to my latest vehicle.
But heres the catch, its not a Honda (though we have a Honda Fit).
Its a Datsun 510 that is soon to have the heart of a Honda.
Everyone does SR20 swaps but I wanted some reliable N/A power and when a friend passed a F20C that needed a rebuild my way I couldnt turn it down!
So im here to learn about these Honda motors and this thing you call VTEC! (VVT i guess)
Old Jun 18, 2013 | 09:20 AM
cerelasergio's Avatar
Default Re: What is this VTEC? ;)
damn that is going to be a pretty cool swap in the Datsun 510 and this web site will tell you more http://www.ehow.com/about_5089357_vtec.html good luck
Old Jun 18, 2013 | 06:32 PM
BlueBandit's Avatar
I do enjoy the instant hatred from the datsun guys when I tell them im putting a Honda motor into my car
But who doesnt want reliable HP!
Old Jun 18, 2013 | 06:45 PM
Moms 94's Avatar
VTEC (Variable Valve Timing and Lift Electronic Control) is a valvetrain system developed by Honda to improve the volumetric efficiency of a four-stroke internal combustion engine. The VTEC system uses two camshaft profiles and hydraulically selects between profiles. It was invented by Honda engineer Ikuo Kajitani, and was the first system of its kind.
Different types of variable valve timing and lift control systems have also been produced by other manufacturers (MIVEC from Mitsubishi, AVCS from Subaru, VVT-i/VVTL-i from Toyota, VANOS from BMW, VarioCam Plus from Porsche, NeoVVL from Nissan, etc.).
VTEC was initially designed to increase the power output of an engine to 100 HP/litre or more while maintaining practicality for use in mass production vehicles. Some later variations of the system were designed solely to provide improvements in fuel efficiency.
Japan levies a tax based on engine displacement, and Japanese auto manufacturers have correspondingly focused their research and development efforts toward improving the performance of smaller engine designs through means other than displacement increases. One method for increasing performance into a static displacement includes forced induction, as with models such as the Toyota Supra and Nissan 300ZX which used turbocharger applications and the Toyota MR2 which used a supercharger for some model years. Another approach is the rotary engine used in the Mazda RX-7 and RX-8. A third option is to change the cam timing profile, of which Honda VTEC was the first successful commercial design for altering the profile in real-time.
The VTEC system provides the engine with multiple camshaft profiles optimized for both low and high RPM operations. In basic form, the single cam profile of a conventional engine is replaced with two profiles: one optimized for low-RPM stability and fuel efficiency, and the other designed to maximize high-RPM power output. The switching operation between the two cam lobes is controlled by the ECU which takes account of engine oil pressure, engine temperature, vehicle speed, engine speed and throttle position. Using these inputs, the ECU is programmed to switch from the low lift to the high lift cam lobes when the conditions mean that engine output will be improved. At the switch point a solenoid is actuated which allows oil pressure from a spool valve to operate a locking pin which binds the high RPM cam follower to the low RPM ones. From this point on, the valves open and close according to the high-lift profile, which opens the valve further and for a longer time. The switch-over point is variable, between a minimum and maximum point, and is determined by engine load. The switch-down back from high to low RPM cams is set to occur at a lower engine speed than the switch-up (representing a hysteresis cycle) to avoid a situation in which the engine is asked to operate continuously at or around the switch-over point.
The older approach to timing adjustments is to produce a camshaft with a valve timing profile that is better suited to high-RPM operation. The improvements in high-RPM performance occur in trade for a power and efficiency loss at lower RPM ranges, which is where most street-driven automobiles operate a majority of the time. Correspondingly, VTEC attempts to combine high-RPM performance with low-RPM stability.
HISTORY
VTEC, the original Honda variable valve control system, originated from REV (Revolution-modulated valve control) introduced on the CBR400 in 1983 known as HYPER VTEC. In the regular four-stroke automobile engine, the intake and exhaust valves are actuated by lobes on a camshaft. The shape of the lobes determines the timing, lift and duration of each valve. Timing refers to an angle measurement of when a valve is opened or closed with respect to the piston position (BTDC or ATDC). Lift refers to how much the valve is opened. Duration refers to how long the valve is kept open. Due to the behavior of the working fluid (air and fuel mixture) before and after combustion, which have physical limitations on their flow, as well as their interaction with the ignition spark, the optimal valve timing, lift and duration settings under low RPM engine operations are very different from those under high RPM. Optimal low RPM valve timing, lift and duration settings would result in insufficient filling of the cylinder with fuel and air at high RPM, thus greatly limiting engine power output. Conversely, optimal high RPM valve timing, lift and duration settings would result in very rough low RPM operation and difficult idling. The ideal engine would have fully variable valve timing, lift and duration, in which the valves would always open at exactly the right point, lift high enough and stay open just the right amount of time for the engine speed in use.
DOHC VTEC
Introduced as a DOHC system in Japan in the 1989 Honda Integra XSi which used the 160 bhp (120 kW) B16A engine. The same year, Europe saw the arrival of VTEC in the Honda CRX 1.6i-VT, using a 150 bhp variant (B16A1). The United States market saw the first VTEC system with the introduction of the 1991 Honda NSX, which used a 3-litre DOHC VTEC V6 with 270 bhp (200 kW). DOHC VTEC engines soon appeared in other vehicles, such as the 1992 Acura Integra GS-R (B17A1 1.7-litre engine), and later in the 1993 Honda Prelude VTEC (H22A 2.2-litre engine with 195 hp) and Honda Del Sol VTEC (B16A3 1.6-litre engine). The Integra Type R (1995–2000) available in the Japanese market produces 197 bhp (147 kW; 200 PS) using a B18C5 1.8-litre engine. Honda has also continued to develop other varieties and today offers several varieties of VTEC, such as i-VTEC and i-VTEC Hybrid.
SOHC VTEC
As popularity and marketing value of the VTEC system grew, Honda applied the system to SOHC (Single Over Head Cam) engines, which share a common camshaft for both intake and exhaust valves. The trade-off was that Honda's SOHC engines benefitted from the VTEC mechanism only on the intake valves. This is because VTEC requires a third center rocker arm and cam lobe (for each intake and exhaust side), and, in the SOHC engine, the spark plugs are situated between the two exhaust rocker arms, leaving no room for the VTEC rocker arm. Additionally, the center lobe on the camshaft cannot be utilized by both the intake and the exhaust, limiting the VTEC feature to one side.
However, beginning with the J37A4 3.7L SOHC V6 engine introduced on all 2009 Acura TL SH-AWD models, SOHC VTEC was incorporated for use with intake and exhaust valves. The intake and exhaust rocker shafts contain primary and secondary intake and exhaust rocker arms, respectively. The primary rocker arm contains the VTEC switching piston, while the secondary rocker arm contains the return spring. The term "primary" does not refer to which rocker arm forces the valve down during low-RPM engine operation. Rather, it refers to the rocker arm which contains the VTEC switching piston and receives oil from the rocker shaft.
The primary exhaust rocker arm contacts a low-profile camshaft lobe during low-RPM engine operation. Once VTEC engagement occurs, the oil pressure flowing from the exhaust rocker shaft into the primary exhaust rocker arm forces the VTEC switching piston into the secondary exhaust rocker arm, thereby locking both exhaust rocker arms together. The high-profile camshaft lobe which normally contacts the secondary exhaust rocker arm alone during low-RPM engine operation is able to move both exhaust rocker arms together which are locked as a unit. The same occurs for the intake rocker shaft, except that the high-profile camshaft lobe operates the primary rocker arm.
The difficulty of incorporating VTEC for both the intake and exhaust valves in a SOHC engine has been removed on the J37A4 by a novel design of the intake rocker arm. Each exhaust valve on the J37A4 corresponds to one primary and one secondary exhaust rocker arm. Therefore, there are a total of twelve primary exhaust rocker arms and twelve secondary exhaust rocker arms. However, each secondary intake rocker arm is shaped similar to a "Y" which allows it to contact two intake valves at once. One primary intake rocker arm corresponds to each secondary intake rocker arm. As a result of this design, there are only six primary intake rocker arms and six secondary intake rocker arms.
Old Jun 18, 2013 | 06:51 PM
Moms 94's Avatar
Old Jun 18, 2013 | 06:54 PM
Moms 94's Avatar
Old Jun 18, 2013 | 07:03 PM
BLU CIVIC's Avatar
Track Advocate
frenchfries413
Apr 3, 2011 05:05 PM
SHG_Mike
Sep 9, 2008 08:27 PM
slammed_93_hatch
17
Jan 28, 2003 06:55 PM
