Transmission problem
Old Feb 2, 2017 | 08:53 AM
Ray Dempsey's Avatar
Default Transmission problem
Hello hope someone can help. I was driving when hand no power like driving in neutral..Pulled over then started moving slightly sluggish but had power enough to move.then no power against pulled over no power no forward gear or reverse engine light came on. Got intouch with friend 2 hours later thought it was a compter said to unplug battery. Tried to move it 1 more time didn't move unplugged battery . Got it to move some what normal. Then like in neutral again unplugged battery got it to move got to AutoZone to get them to check the light because I unplug the battery it was not did not come back on. Moved the no power like it's in neutral battery trick did not work tried three times came back the next day got to move go home woodwork unplug battery would work kind of sometimes it would only be second gear sometimes it would be no gear sometimes it would work just fine all the gears r changed no problems then sluggish driving in neutral transmission fluid no smell burnt no noises I think it's a solenoid don't know which one can somebody help thank you
HFpower
Oct 16, 2009 09:30 PM
mysterysktr7
Jul 10, 2009 09:09 PM
integraboy
Jan 19, 2005 11:56 AM
People_Mover
Jun 9, 2004 01:37 PM
HatchBox
Oct 24, 2003 06:10 AM
