Throttle cable help!!
Old May 8, 2024 | 08:03 AM
Unikboyb's Avatar
Default Throttle cable help!!
Hi my name is unik. I have a 1992 eg with a b20b and my throttle cable gets stucks often, i want to replace it but don’t know if i would just look up throttle cable for 1992 civic or if it’s a specific one seens it has a b series please help!! With a part number anything!!
Old May 8, 2024 | 11:37 AM
95_civic_gsr's Avatar
Default Re: Throttle cable help!!
You can look up part numbers and illustrations from online Honda parts dealers. Even your own local Honda dealer should have an online store.
These are two that I buy from all the time:
Majestic Honda -Honda Automotive Parts.com
Honda OEM Parts Online
Look up the car you're driving, then look up the vehicle the engine came from. Compare those throttle cables to the one you're currently having a problem with. If it still doesn't match, look up other years and versions of the B-series motors. 92-95 civic d15/d16, 97/98 CRV, 99-00 CRV, LS/GS/RS/GSR, 90-93, 94-97, 98-01
Old May 9, 2024 | 08:17 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
For an EG chassis, the best way to get the throttle cable right is to get the cable and mounting bracket for the model/year intake manifold that you have installed on your B20B. Assuming that the throttle wheel isn't significantly different in size compared to that found on the throttle body that originally matched the intake manifold... you should be fine.
eggsi619
Aug 5, 2009 10:03 PM
646EG
Feb 17, 2008 08:21 AM
vmm
Aug 21, 2004 08:12 AM
