Skunk 2 Tuner Stage 2
Old Jun 8, 2022 | 01:11 AM
Jegs's Avatar
Default Skunk 2 Tuner Stage 2
Hi, I’m new to all this so you’ll have to bare with, I’m in desperate need of answers to this question I ordered a set of Skunk 2 tuner stage 2 camshafts to put into my b16a2
The engines been fully rebuilt
stock bottom end with new rings and Acl bearings
valvetrain has all new skunk 2 dual valve springs and retainers, new skunk 2 alpha valves and new loss motion assemblies.
we are at the point now of putting the sk2 tuner stage 2 camshafts in however we’ve run into a issue which there isn’t a lot of answers out there to this but are cam gears required? As I brought them to the understanding they were just drop in cams, check the valve to valve clearances and piston to valve clearances and that’s it, I’m not bothered about loosing a potential 1-3 hp but if I can get away with using stock cam gears on these camshafts provided the clearances are okay.
are these cams okay to use without cam gears? Any information is greatly appreciated
Sagara09
Jun 7, 2012 04:54 PM
RiSiNgDc2
Mar 9, 2006 03:53 PM
h22vt
Jan 26, 2006 03:15 PM
AK94GSR
Aug 17, 2003 02:39 AM
kwik93si
May 2, 2003 03:58 PM
