No power to fuel pump
The main relay actually has two relays inside. Each relay is a normally open type relay. When voltage/power and ground are applied to the respective relay coil, it energized the relay coil and closes the respective internal relay contact to allow power through.
There are several power and ground sources necessary for the relay to operate. For example, if the ECM does not send the ground to the relay coil, then no power will be allowed through to the fuel pump.
OP: You should have posted your help question here: Honda Civic/Del Sol (1992 - 2000) - Honda-Tech
Very true..it was my assumption that he tested both power and ground at all points entering and exiting the relay. After re-reading the OP, I see that wasn't the case.
Great information tho, the OP needs to test all power/ground points on the relay
elsmiles
14
Aug 16, 2021 12:14 PM
06turbocivic18
Apr 24, 2009 07:17 PM
95turboeg
Jul 7, 2006 11:38 AM
