new need help!
Old Apr 25, 2014 | 01:19 PM
Based_DB8's Avatar
Default new need help!
Hello everybody im new to honda tech and the reason why I joined is because I installed coilovers on my 97 Db8 when they were maxed out as low as they go my front wheels began to shake at speeds greather then 5mph. I changed my axles and It continued to shake. After raising the coils it stopped shaking. What could it be?
Old Apr 25, 2014 | 05:56 PM
mitsuguy85's Avatar
Default Re: new need help!
did you install new lower ball joints up front? those might help. but still still wouldn't explain an aggressive shake at only 5mph. Did you forget to tighten something or do you have a rubbing issue possibly?
Old Apr 25, 2014 | 05:59 PM
95accordCE6's Avatar
Sounds like improper toe adjustment, it needs to be adjusted each time ride height is changed, also could be the axle angle causing a vibration
CRXguy_88
14
Oct 17, 2010 08:00 PM
715_guy
Mar 12, 2007 02:58 PM
DeDonDeRosa
Sep 21, 2006 07:17 AM
Civic138
Sep 16, 2003 03:35 PM
brian estrada
Apr 16, 2003 03:04 PM
