New Here
Old Oct 13, 2020 | 05:53 PM
Rob Potts's Avatar
Default New Here
What is good everyone. I'm Rob. I'm going to try and piece together everything I've done on my 92 prelude and the little quirks etc, I've run into or, solutions to things I've encountered.
I like to consider myself a noob as, I haven't gone to school or was a tech etc... I just found a passion for Honda's after my time in the service. I look forward to interacting with you all.
PS.. "trolls or know it alls" can eat a fat one. I got most of my information thru the years, here. Except from y'all, you get skipped over quickly.
If ppl do that, others .. please ignore it and stick to the topic. I hate threads that are all over the place.
Old Oct 13, 2020 | 06:14 PM
Rob Potts's Avatar
Default Re: New Here
I've got a 1992 Prelude Si
H22A1 swapped
M2B4 Lsd trans
And literally bolt ons.
Grabbing a p13 ecu shortly
Running p14 h23 ECU
H23 engine harness
Tokico shocks
Tein springs
Imma just put the list of maintenance repairs I've ran through.
Head gasket
Timing belt/water pump
Manual tensioner swap
Both Axles
Output shaft seals (this one was hard to find for one side)
Outer tie rods/inner tie rods
A\c deleted with the right belt (no tension issues)
New h23 alternator (to work the belt)
Reman ps pump\new belt
Every vacuum Line (only one in question)
Brakes and rotors
Distributor and swapped the rotor and cap to a better one
Plugs and wires are ngk
Valve cover gasket
Intake and exhaust gasket
Knock sensor
345cc OG Honda oe injectors
Aem (typical) intake
(Not eBay but unknown 4-2-1\straight\muff exhaust set up (may change)
O2 (I hate doing these)
Radiator fan delete
Thermostat
Upper ball joints and control arms
Syncromesh trans fluid change
Zero issues RN on the p14.
I'll update as the p13 is obtained.
PS* motor only has 109k miles
Transmission has just about 90k miles
Old Oct 13, 2020 | 06:31 PM
Rob Potts's Avatar
*end links are\Upper and lower rad hoses\slave cylinder done as well*
The line up for the "next up" maintenance
FRONT\REAR calipers
FRONT\REAR brake lines
Sway bar
(potentially a master bushing kit as well)
Cannot find rear upper control arms sooo....?
Rear ball joints\upper ball joints
Aftermarket radiator.
PS cooler delete (just loop it)
(PS delete\gotta find out how\i want a manual rack)
This may have items added, just off the top of the head.
All window and wiper motors
Every relay in the car including "Main"
Goal is to have every window replaced. The driver and windshield are up first, at the end of the month.
