Need DA Integra Help!!
Old Feb 20, 2019 | 03:49 AM
GreenDemon93Ls's Avatar
Default Need DA Integra Help!!
Hello i Just recently bought a automatic 93 Dark Green Integra that appeared to be in decent condition. No body damage motor sounded quite no ticks, it had a hood and trunk latch issue easy to fix. Now after a couple days of normal non abussive driving im having a ongoing issue that is only getting worse. It started with a hesitant initial acceleration that corrects itself but almost acts like it is going to stall out. It also will either idle rough or occasionally pulse, and the lastest additon to this is it died and flashed the S3 light with all other indicator dash lights solid and would only crank had to turn key on and off several times to finally start. A seperate time it only died at an idle and no flashing s3 indicator just took a couple minutes to start again. Where do i begin to Fix before i get stranded.? Previous DA i owned had the main relay go out easy fix but didnt act like this at all so im skeptical of that solution.
GreenDemon93Ls
Feb 20, 2019 09:42 AM
potatointegra01
May 12, 2015 09:34 AM
My_EFsedan
30
May 16, 2013 05:32 PM
My_EFsedan
Oct 30, 2012 07:26 PM
WEEZY034
Aug 31, 2007 05:43 PM
