I need help
Old Jan 13, 2023 | 01:14 PM
Namrondatsnave's Avatar
Default I need help
Purchased a 94 accord ex 5 speed with 67k back in march of last year. when i went to look at it it ran perfect with some cosmetic issues. When i picked it up had nothing but full on problems. (items i have replaced) Alternator seller said it was locked up i took the belt off to hear it run. After picking up have replaced ignition completely, distributor, plugs, (cleaned iacv and fitv) (even screwed that plastic piece in), main relay, ecu,bled the coolant, new fuel pump. ran good on the new ecu till it didn't. (wont prime the fuel pump now) switched back to the old ecu which will prime the fuel pump it will start and shut off after a second or 2. When i can get it to idle it will bounce up and down very erratically. ive cleaned the majority of the grounds. Im lost and about to send this car to the burning abyss any thoughts or things i haven't done will be greatly appreciated. hi guys new to forums lmao
Old Jan 13, 2023 | 01:32 PM
Default Re: I need help
Also forgot to mention it has a code 14 and 15
oresama
31
Jan 19, 2025 10:47 PM
mujunyu520
Oct 19, 2022 01:00 PM
keeganeli
42
May 17, 2015 03:36 PM
crxowner
Oct 2, 2007 05:49 PM
