HELP!!
Old Jul 26, 2013 | 03:59 PM
macdaddyfitch's Avatar
Icon3 HELP!!
Hello I just bought a 90' Civic Si Hatch with 190xxx miles on it for 900$.. I already blew it up. literally the day after I drove it home and really need some help on doing a motor swap. not looking to beef it up at all just looking to do a stock swap straight bolt on to get her running again. I did some research and found out it had a D16 ZC sohc non-vtec.. I honestly cannot find one ANYWHERE and really need some advice on an easy swap that doesnt require a lot of modification(new wiring harness, motor mounts, intake etc..) and im also on a VERY tight budget so i need to keep that in mind too. Please help! im new to cars too (this is my first car) so any type of info/advice will be of help! Thanks!! ill have pics up as soon as i am a full member on the site..
Old Jul 26, 2013 | 04:57 PM
elmanre's Avatar
Default Re: HELP!!
Hello boy, first well this is not the correct section, try to read the forum rules.
Second, you can put a D16Z6, D16Y8 motor, those are going to be easy swap on your car if you already have a ZC, and probably you don't need to change your harness or motor mounts!!
Old Jul 26, 2013 | 05:28 PM
Default Re: HELP!!
sorry didnt know about other section im new to this.
and thanks i didnt know they were almost the same motor ill have to check them out.. also do you know it they will be a straight bolt on the my transmission?
macdaddyfitch
Jul 26, 2013 08:29 PM
Diggin DelSol
Jan 26, 2005 11:22 PM
