Hello Honda tech
Old Aug 14, 2014 | 08:39 PM
98EGY8's Avatar
10 Year Member
Default Hello Honda tech
hello everyone, used this site many times to get me out of jams, finally made an account and finally made this post. im outa CT and i gotta 98 civic ex coupe that i picked up in early 2012, so ive had it for about 2 1/2 years now. ill go over what its got, mods it has, mods i got sittin around and mods i plan on getin. the idea behind this build is to be better than an si for cheaper than an si,but look exactly like an si
motor:B18C1, skunk2 pro1 cams, skunk2 springs/retainers, wiseco pistons 11.1-1 CR, ITR rods,ACL bearings, stock crank,jdm type r oil pump, type r replica intake manifold,stock gsr throttle body, 440cc rc injectors, aem fuel rail and regulator,PLM headers,AEM v2 intake for EK D16Y8
stage1 cutch flywheel pressure plate
stock ls transmission
innovative mounts
hondata s300,aem AFR gauge
skunk2 shocks/springs,LCAs,strut bars
i got s2 70mm TB for motor and yonaka exhaust to put on also, i have some rotas? one of them is curbed bad and 2 of them are showin belt from camber, dont got the money to get it fixed. i gotta civic si lsd tranny and the reverse dont work so gotta get that fixed sometime also.
im on the lookout for a rear disc brake conversion,adjustable camgears, new IM, and air intake for 70mm.
thoughts, opinions, suggestions, constructive criticism. all welcomed
Old Aug 15, 2014 | 04:22 PM
Need 4 Speed's Avatar
Default Re: Hello Honda tech
Welcome to Honda-Tech. Glad to have you on-board!
Codyv17
42
May 22, 2016 08:48 AM
SpoonEk253
24
Jan 10, 2008 05:27 PM
all_motor_sfwd
Apr 25, 2007 11:25 PM
Gatweb
23
Mar 9, 2005 06:39 PM
Gatweb
Nov 5, 2004 10:09 AM
