B20 misfire
Old Aug 1, 2024 | 11:44 PM
Jamieb20rd1's Avatar
Default B20 misfire
So I’ve got a strange misfire if I pull the leads off cylinder 2 and 3 it doesn’t change the idle at all
I’ve changed
injectors , plugs , leads rotor , cap , timing belt , throttle body idle controll valve , compression test is at 175 on all 4. Valves have been adjusted
I’m lost ….. any ideas what to try next I don’t want to pull the head off unless it’s last resort
Old Aug 2, 2024 | 08:20 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: B20 misfire
If the compression test came out as you have stated, there is no reason to pull the cylinder head. Beginning from the cam gear end of the engine, what are the colors of the ground wires on each fuel injector plug moving toward the distributor ? The order should be Brown, Red, Blue, and Yellow. If the middle two are switched, move them back and see if your problem persists.
daveatron09876
Jan 27, 2024 06:23 AM
Tommurray
Dec 2, 2015 07:13 AM
92DAb20b
Nov 15, 2012 09:54 AM
SkidmarkEH2
Apr 25, 2010 09:47 PM
eric1180
Feb 13, 2010 11:14 PM
