93 eg coupe
Old Feb 5, 2025 | 08:02 AM
Brickhouse's Avatar
Default 93 eg coupe
I have an eg with a b20b4 with a cable trans out of a 91 teggy I need to know what axles to buy I wasn't sure if the dimensions the same as the b series hydro trans
Old Feb 5, 2025 | 05:48 PM
theYBLEGAL's Avatar
Loved
Default Re: 93 eg coupe
Yeah it's the same. Cable and hydro LSD I know first hand are the same so axels must be the same.
Old Feb 5, 2025 | 08:18 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The right side axle will work either way, although the '90-93 axles are just slightly shorter. The left side axle chosen will depend on which mid-shaft you use... cable shaft uses the '90-93 axle and the hydro shaft uses the '94-01 axle.
d.whiz
K Series
Apr 2, 2012 11:10 AM
914b16
Feb 22, 2011 01:21 PM
skromee
Jan 13, 2011 07:04 AM
jrp355
Nov 30, 2010 04:45 PM
carbonkandy
Apr 23, 2007 06:24 AM
