Current List And Mods
Engine
B18c1 - 94 Integra
Obd2b-Obd1 Harness
P72 ECU
CAI- Custom Short Ram
Blox Tuner Series 68mm Thottle Body
Blox V3 Manifold
Test Pipe
O2 Defouler Angled
AC Delete
Power Steering Delete
NKG Spark Plug Wires
New Gates Timing Belt @ 155K
Secondary Timing Belt Tensioner
New GMB Water Pump @ 155K
Evap Relocated and mounted
Transmission
99-00 Civic Si Transmission
Competition Stage 2 Clutch
B&M Dual Bend Short Shifter
Stainless Braided Clutch Hose
Suspension
skunk2 Rear Full Coilovers with shock
97-00 Civic Type R 5 Lug Conversion
ARS V2 1" Rear Swaybar and Reinforcement Kit
Lower Control Arm Bushings
Brakes / Wheels
98-01 Type R Wheels
97-00 Type R Front And Rear Drilled And Slotted Rotors
Interior
99-00 Si Gauge Cluster
99-00 Si CLimate Control
94-01 Integra Shift ****
Alpine Head Unit
Rear Windows Tinted
94 Integra Interior
2nd Battery in Trunk
240Amp Fuse Block By Shifter
CLothed Rear Speaker Grills
Reclothed Center Arm Rest
Exterior
Antenna Delete
99-00 Si Grille
99-00 Si Rocker Panel
99-00 Civic Fog Lights
