zc swap help!!!
Old Oct 2, 2002 | 12:06 AM
shinobes's Avatar
Default zc swap help!!!
OK...here is what I need to know. I have been finding it so hard to find accurate zc info on the internet. How the hell can you tell if a zc is the 130hp output engine. I just recently bought a zc from attarco, everything looks the same, it has the oil to water cooler, says zc on the block, but some small things are different. for example, my si throttle body, which is supposed to be compatible, isn't. Another thing is the distributor doesn't have an internal coil, and it seems that the engine mounts are in the right position, but are off by about a centimeter. They look like the b18c mounts. Anyone have any reliable information for me? The date stamp
says 1992. Any help would be appreciated. Thanks
Old Oct 2, 2002 | 06:04 AM
jlicrx's Avatar
Default Re: zc swap help!!! (shinobes)
sounds like you may have integra zc which is different from civic/crx zc - what color is valve cover - brown for integra - black for civic/crx - what car is it going into?
Old Oct 2, 2002 | 06:09 AM
EP3_05's Avatar
There was never an integra ZC. The only ZC made came out of the JDM 88-91 civic/crx Si. The brown cover motor is the d16a1 out of the early gen US integras. Europe has the d16a9 as well...which is basically a ZC but stamped d16a9.
[Modified by 91civic, 10:09 AM 10/2/2002]
Old Oct 2, 2002 | 06:13 AM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: zc swap help!!! (91civic)
heh sounds like you got a 92-up ZC.
they came in the 10th anniversary edition hatches.
Old Oct 2, 2002 | 06:14 AM
EP3_05's Avatar
Default Re: zc swap help!!! (two.oh)
Oops I forgot about the rare OBD1 ZC...blah
Old Oct 2, 2002 | 06:21 AM
jlicrx's Avatar
sorry to disagree, but i have two jdm zc - brown valve cover - sitting in the garage
Old Oct 2, 2002 | 06:26 AM
EP3_05's Avatar
Default Re: zc swap help!!! (jlicrx)
What year is stamped on those blocks???
Old Oct 2, 2002 | 06:28 AM
jlicrx's Avatar
one is 86 - one is 87
just noticed his original post says stamped 1992 which would mean it is the sohc zc
[Modified by jlicrx, 3:30 PM 10/2/2002]
my son owns zcspeed racing and this is the motor that we use for 1st gen crx swaps since they practically bolt in
[Modified by jlicrx, 3:43 PM 10/2/2002]
Old Oct 2, 2002 | 08:56 AM
freakin_eLRoD's Avatar
2nd Gen DOHC ZC came out of the 92 civic 10th anniversary edition courtesy of Katman:
notice the grey plugs on the distributor:
Honda also came out with the dohc zc and the sohc non vtec zc aka d16a6 in the US (i believe 88-91) and the sohc vtec zc (basically the d16z6 with "zc" stamped on the block in 92-)
[Modified by 96jdmcoupe, 5:59 PM 10/2/2002]
ramirocka
Jan 21, 2018 11:02 PM
91CivicEF
Jan 7, 2009 06:42 PM
Yaa
Sep 8, 2005 04:32 AM
DOHC_EF
13
Jun 4, 2004 09:39 PM
LSVTECKING
Sep 9, 2003 05:42 PM
