Z10 Radius rods
Old Aug 31, 2001 | 05:41 AM
91sifreak's Avatar
New User
Default Z10 Radius rods
I have A 91 si hatchback with a b16a, anyone every tried those Z10 Radus arms yet? just curious because i would like to get them but just seeing if any of you have any experience with them, and it really doesn't matter what you tried them on, just trying to see what the overall effect of having them installed was. thanx
Old Aug 31, 2001 | 06:50 AM
WAFFLES's Avatar
Default Re: Z10 Radius rods (91sifreak)
Did you read the review of them on the hybrid page?
Old Aug 31, 2001 | 11:02 AM
91sifreak's Avatar
New User
Default Re: Z10 Radius rods (WAFFLES)
yeah I was impressed, just seeing if anyone else had any experience with them, know what I mean.
Old Aug 31, 2001 | 03:00 PM
Full-Race Geoff's Avatar
We do have a few EF kits out there. All the customers have been very pleased. Here is a link from a guy using one of the older designs. The new designs are even beefier, and lighter.
http://forums.clubsi.com/ubb/Forum37/HTML/000385.html
Jason is a top contender in power 4 and IDRC quick classes. Often is the fastest honda street car at the east coast races.
Old Aug 31, 2001 | 05:46 PM
fixhondas's Avatar
Default Re: Z10 Radius rods (z10 geoff)
how much more effective on a crx are the z10 rods compared to stock rods with urethane bushings? I put some prothanes in and the car takes off much quicker.
Old Aug 31, 2001 | 07:33 PM
Gmedalion's Avatar
Hey z10 geoff, does it work for the type R??
Old Sep 2, 2001 | 06:47 PM
Default Re: Z10 Radius rods (fixhondas)
The kit works quite a bit better than the stock crossmember, for a couple of reasons. First of all, the stock crossmember is very large and bulky and does not allow one to run a large header/downpipe. Secondly, the caster is not adjustable. Finally, even tho the bushings are much stiffer than the stock rubber ones, they are still flexy and nowhere near as stiff as a solid rod end connection.
FWIW, jason (lilbluecrxwilleatyou) had a set of urethane bushings in the car before he put our xmember on. Once he got the xmember on, he had 60' times that were a full 10th better than before.
Old Sep 2, 2001 | 06:48 PM
Default Re: Z10 Radius rods (Gmedalion)
Yes we do make a kit for the ITR. It is different from the EF kit, however but it is the same kit as the EG/EK/DC.
for info on this kit read the hybrid article at http://hybrid.honda-perf.org
[Modified by z10 geoff, 3:49 AM 9/3/2001]
Old Sep 2, 2001 | 09:36 PM
SactownXSi's Avatar
Does the EF kit fit on a DA?
-Nick
Old Sep 3, 2001 | 04:02 AM
JDM_DOHC_SiR's Avatar
New User
Default Re: Z10 Radius rods (SactownXSi)
Nope the USDM front member is different than the DA but my JDM EF-8 haas the same member as the DA
Geoff....DO ya have the DA's done yet or are they still on the back burner..?? let us know when you can I still have money burning a hole in my pocket &lt;HINT&gt;&lt;HINT&gt;
Old Sep 3, 2001 | 05:21 PM
Default Re: Z10 Radius rods (JDM_DOHC_SiR)
The DA kits are all figured out. I will call the shop tomorrow and let you know the details. They should have been finished a few weeks ago, i had everything taken care of. But then i left for school...
Thanks for waiting dave. youre really really cool.
Old Sep 3, 2001 | 06:19 PM
New User
Geoff your Da man
Old Sep 3, 2001 | 08:10 PM
Lyonel's Avatar
Interesting... I didn't know the EF8 has the same c-member as the DA . Any other parts inter-changeable from the EF to DA? ie. rear-swaybar, strut braces, etc.
Old Sep 4, 2001 | 06:21 AM
New User
Default Re: Z10 Radius rods (Lyonel)
There are only a few parts that can be brought over from and too these cars the strut tower bars will work the rear sway won't work without modification ..also to small and as for the front sway bar it mounts different than any other honda that worked on..
Old Sep 4, 2001 | 07:16 PM
555R's Avatar
i have been running them since october and road race on them regularly
i do have to do a visual inspection sometime because while racing at Watkins Glen I did hit the curbing hard enough to have my Spoons contact the brakes so i want to see if they are tweaked
howver they work fantastic
and no problems otherwise
i just dont see how there can be any probs
Old Sep 5, 2001 | 10:46 AM
paulzy's Avatar
Default Re: Z10 Radius rods (555R)
man, are they worth the 500 bucks retail? If it's worth it, then I would buy it, but holy crap, 500 bucks
Old Sep 5, 2001 | 11:51 AM
jg's Avatar
jg
555r- What differences did you notice? Understeer changes? Braking? etc.
Old Sep 6, 2001 | 05:48 AM
Tbone's Avatar
Jdm dohc sir,
Does this apply to the usdm models or just the jdm ones? When you say same do you mean exactly the same? Will I gain any header clearance by switching to the da version?
Old Sep 6, 2001 | 05:53 AM
New User
Default Re: Z10 Radius rods (Tbone)
Nope only the Japanese EF-8/9 share the same front member as the DA Integra
Look
Old Sep 6, 2001 | 08:38 AM
91sifreak's Avatar
New User
So on the USDM 91 Si the kit replaces the whole front crossmember....hmmm, funny I was just thinking about replacing it so I can fit the new header, how much did I hear that thing is 500.00, man i hope it all worth it, cause i want it....
[Modified by 91sifreak, 6:12 PM 9/6/2001]
Old Sep 6, 2001 | 01:20 PM
Lyonel's Avatar
Fastbrake's Z10 Radius Rod kit impressions https://honda-tech.com/zerothread?id=66463
Old Sep 7, 2001 | 03:18 AM
solorexer's Avatar
Does the Z10 crossmember use the factory front engine mount on a 2nd gen CRX like the factory crossmember? Are you able to keep the factory splash shields? Is it legal for SCCA solo2 in Street Prepared class?
Old Sep 7, 2001 | 05:26 AM
hvtec93's Avatar
New User
Default Re: Z10 Radius rods (solorexer)
I have that kit installed on my 93 civic
and it works pretty good not only it improves handling and wheel hop, but the whole fron end feels rock solid now
Old Sep 7, 2001 | 06:00 AM
91sifreak's Avatar
New User
Default Re: Z10 Radius rods (hvtec93)
does it push or pull the front wheels in any direction in the wheel well.
Old Sep 9, 2001 | 02:20 PM
The EF kit allows one to both "push" and "pull" the wheels. The EG/EK/DC kit only allows you to pull.
Setting up a car properly usually means adding caster by pulling the wheel forward... that is what works the best on a fwd car, so the option of pushing the wheel back is there, but it really isnt a wonderful option.
