Wiring Problems HELP !
i have a 97 civic with a ( 2000 b18c1 ) with a ( 97 GSR ecu ) what wire harness do i need in order to make this converstion work? can it be a bolt on with the right harness. Will it work with just a 96-99 ex, hx or si harness ? the harness that came with the car is custom and it's not running right.
Modified by EGkwazhimoto at 9:29 PM 1/20/2004
use your existing harness....only a 96-98 harness will work with the interior harness...all you have to do is add vtec, pressure switch,knock sensor,IAB, and some modifications to your IACV wiring and IAT...if you have any questions hit me up...
mark78214
Feb 23, 2009 05:57 AM
EJtypeR
May 20, 2006 01:16 PM
TheBestCRX
Jan 28, 2003 07:08 AM
