wiring problem, crank sensor???? help please!
were putting a 2001 b16a2 swap into a 93 si delsol..everything is in and wired with the si harness...and swapped the p28 for a p30. my question is, what the hell should i do with the crank sensor? i heard that the p30 wont read it and its useless,that i need an obd1 sir dizzy,that my car wont start or will run on limp mode... ect.. wich is true?? and what is the sensor just above the fuel rail for??
any kiind of help would be much appreciated.
thanx guys, the obd1 dist. is on its way. but will i have any problem with my vtec engagement??
and anybody knows what is that sensor on the fuel rail for??
thanx again!
thanx again!
sensor on the fuel rails is for the charcole canister.one hose goes the the intake vac. and the other goes to charcole canister.vtec will work.
DelSlowmo
Mar 13, 2010 11:00 AM
poorhonda
Jun 2, 2008 11:44 AM
