wiring harness
Old Aug 28, 2006 | 07:45 PM
beoy9's Avatar
Default wiring harness
Ok, I've searched and found lots of good info, just not exactly what I need, or am hoping for maybe.
I've got a 95 DX and I'm in the process of swapping in a JDM B18C. Through all of my searching I've figured out everything from pulling the motor to vacuum lines. The trouble I'm having is with wiring. I've found the following as far as the harnesses are concerned
USDM GSR harness will work the best, as all I'll have to do is run a few wires through my firewall to the ECU
EG Si or EX harness is the next best thing as the engine harness is prewired for vtec
What I'm wondering is if in my situation, would it be possible to remove the B18C harness and disect it and reroute the wiring to the opposite sides and then throw it all back in those looms and then wire the firewall? Or could I take my DX harness and ad the wires/plugs I need?
I've looked over both motors side by side and there are a quite a few plugs I'm missing on my civic harness. If it's possible, I'd like to cut up my GSR harness and rewire it in the looms because I stand a better chance of getting everything wired up.
Or should I just camp ebay for a USDM GSR or EG vtec Harness? Help me HT!
Old Aug 29, 2006 | 01:19 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: wiring harness (beoy9)
just use your factory harness with a subharness, its plug and play
Old Aug 29, 2006 | 06:27 AM
beoy9's Avatar
Default Re: wiring harness (HondaPartsHero)
By factory you mean my DX harness, and by sub harness you mean those you are selling? I'd need the IAB harness too. Good god, if this is the case, then THANK YOU!!
89ED
Feb 20, 2015 11:27 AM
crazy-teggy-ls
May 5, 2009 08:20 AM
Rusty Shackleferd
Jan 25, 2005 11:28 AM
