wiring - 92dx
Old Jan 7, 2004 | 01:51 PM
3.3.3's Avatar
Default wiring - 92dx
wiring was cut up when the car was stripped...from the ecu and the engine bay. do you guys think its better to just rewire the whole thing, or try to patch it up?
Old Jan 7, 2004 | 02:36 PM
JDMH22HATCH's Avatar
Default Re: wiring - 92dx (makS)
I personally would replace the harness to avoid the headaches. If you do decided to match everything up and fix it, then make sure you solder and heatwrap it correctly. You wouldn't want to have to trace back all you steps and find the one wire that could have been done wrong. Good luck
Old Jan 7, 2004 | 02:45 PM
3.3.3's Avatar
Default Re: wiring - 92dx (JDMH22HATCH)
thanks man...i figured i should just do that, but im a little impatient....
max
Old Jan 7, 2004 | 02:51 PM
If you are impatient, then definitely replace the harness matching every wire up will take some time and definitely some drinks.
Old Jan 7, 2004 | 02:55 PM
3.3.3's Avatar
to you.
Old Jan 11, 2004 | 01:39 PM
s2kintegra's Avatar
replace the harnesss for sure,
Old Jan 11, 2004 | 03:24 PM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22HATCH &raquo;</TD></TR><TR><TD CLASS="quote">I personally would replace the harness to avoid the headaches.</TD></TR></TABLE>
Definitely, if it's all hacked just replace the cabin harness. It'll be much easier in the long run and you won't end up wanting to yourself trying to rewire it all.
Old Jan 11, 2004 | 05:13 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by makS &raquo;</TD></TR><TR><TD CLASS="quote">thanks man...i figured i should just do that, but im a little impatient....
max</TD></TR></TABLE>
Replace it. I almost killed myself when I had to rewire a whole harness on a car (it was not a honda, it was a LS1 into a 3rd gen camaro, I still have nightmares).
DOHCtec
Sep 27, 2018 01:11 AM
95coupeb
63
Sep 3, 2010 06:27 AM
strtrcr77
Dec 5, 2009 09:45 AM
Markb16a
Nov 17, 2005 05:56 PM
ITR.#1446
Oct 2, 2004 11:02 AM
