Where do i start????????
Old Dec 16, 2007 | 08:33 PM
Keeper1343's Avatar
Default Where do i start????????
I have a H22 civic. Right now i have a few problems that i don't know how to approach.... Lets start with CEL codes. Code 1 and 43 on a P28. Thats a o2 sensor and Fuel delivery. Some times they throw at the same time i hear. Well i replaced the sensor and reset the ECU. Well it came back. But there are some symptoms that can be causeing the same things to happen... For instance, sometimes when i start my car up the idle surges like there is a vaccum leak but goes away after 4 surges or so. But i can't find any leaks when i spray with starter fluid.
Well heres the thing. If theres a vaccum leak it could trip code 1, then that trips code 43. Or maybe the surge is caused by bad fuel pressure and trips the o2 as well. HELP WHERE DO I START
Old Dec 17, 2007 | 03:06 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Where do i start???????? (Keeper1343)
the 43 is a fuel issue problem usually a rich code if i remember. what is done to the fuel system?
Old Dec 17, 2007 | 06:49 AM
Keeper1343's Avatar
Default Re: Where do i start???????? (boostedcivicsir)
the fuel system is stock
Old Dec 17, 2007 | 06:56 AM
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keeper1343 &raquo;</TD></TR><TR><TD CLASS="quote">the fuel system is stock</TD></TR></TABLE>
do you have a fuel pressure gauge? maybe reg is bad and is stuck at like 60+ psi...could be an issue.
Old Dec 17, 2007 | 11:10 AM
Keeper1343's Avatar
Default Re: Where do i start???????? (h2b_eg8)
so to test it i would guess hook it up after the regulator??? And what be causing the o2 sensor to trip all the time???
Old Dec 17, 2007 | 11:17 AM
high_revs's Avatar
no, before the regulator....like at the fuel filter.
burfy
14
Nov 16, 2011 07:53 AM
crxsteve
Sep 12, 2007 08:06 AM
RS'R'
Jan 13, 2007 05:48 PM
str8JDMteggy
Sep 29, 2006 08:27 AM
KiD Fr0m Da 516
Feb 20, 2006 09:04 PM
