wheels spin in neutral..???
Old Feb 10, 2003 | 01:29 PM
baonest1's Avatar
Default wheels spin in neutral..???
i have a 98 JDM tranny on a Ls/vtec. i have the car on jackstands and i sit in it and when i turn the car on the wheels spin in neutral and even the speede (canadian ITR) goes up.... the speedo is totaly out of calibration but it still moves.. is this a shift linkage problem?? this is all in a 2000 LS. oh and i have a short shifter too.
thanx
Old Feb 10, 2003 | 01:58 PM
Stroker
Guest
Posts: n/a
Default Re: wheels spin in neutral..??? (baonest)
no its no big deal.
Old Feb 10, 2003 | 02:02 PM
VTECVillain's Avatar
My friend has a 96 JDM B18C swap and his did the same thing after the swap. You can stop the wheel by hand and there is no resitence at all. It might have something to do with the LSD but I'm not sure.
Old Feb 10, 2003 | 02:10 PM
baonest1's Avatar
Default Re: wheels spin in neutral..??? (VTECVillain)
good deal guys.. thanx.
Old Feb 10, 2003 | 05:46 PM
Jaker's Avatar
Its just light drag in the gearcase. It is totally normal.
Old Feb 13, 2003 | 05:05 AM
Muckman's Avatar
Moderator in Chief
Default Re: wheels spin in neutral..??? (Jaker)
LSD's do funky ****. My wheels rotate slightly when just putting it in gear, with the clutch pressed to the floor. (car jacked up)
Old Feb 13, 2003 | 03:46 PM
DanielLaruso's Avatar
Default Re: wheels spin in neutral..??? (Muckman)
quick question to guys with LSD, this past wekend i swapped in my sir and lsd as well, question is....is it normal to hear a lot of noises with an lsd, clicking and such?
thanks
Old Feb 13, 2003 | 05:46 PM
khang77642's Avatar
Default Re: wheels spin in neutral..??? (DanielLaruso)
its normal
Old Feb 18, 2003 | 10:52 AM
Vic Nyce's Avatar
hell my 96 EX does the same thing
Old Feb 19, 2003 | 09:13 PM
IDriveHonda's Avatar
It is referred to as inertia. All of the spinning within generates an energy kind of which transfers through out, or:
in·er·tia
Pronunciation: i-'n&r-sh&, -shE-&
Function: noun
1 a : a property of matter by which it remains at rest or in uniform motion in the same straight line unless acted upon by some external force.
Yea I thought it was pretty messed up to but it does it on most cars. Yea, I had to use the dictionary
Old Feb 19, 2003 | 10:11 PM
baonest1's Avatar
Default Re: wheels spin in neutral..??? (IDriveHonda)
lol... thanx
k624ash
Transmission & Drivetrain
Feb 4, 2009 09:23 AM
davidluko
Mar 14, 2007 04:24 PM
MackDad
Aug 24, 2006 06:22 PM
KOALA YUMMIES
Mar 23, 2003 07:40 AM
Stop the Beast
Mar 7, 2002 03:42 PM
