What would be better for Ls/Vtec?
Old Sep 1, 2001 | 07:55 AM
MXPX's Avatar
New User
Default What would be better for Ls/Vtec?
I was just thinking this and its boggling my mind. Would a B16 head with Skunk2 intake manifold be better then a b18c1 Head with Skunk2 intake manifold. Or is it the other way around, i would think that a b18c1 head with Skunk2 would be better. And also...How much better is an Integra Type-R throttle body then a stock B16 or b18c1? Becuase if i did this my way i would port the Integra type-r throttle body with the b18c1 head and skunk2 intake manifold...Please help me out here thanks
Old Sep 3, 2001 | 08:25 AM
Slacker's Avatar
Default Re: What would be better for Ls/Vtec? (SlooowEG)
price wise the B16 is the better deal. But hp wise the B18C is better. One reason is because the B18 cams are better. If your going to do a cam swap then I would go with a B16. Skunk2 intake is also cheaper for a B16 than a B18. And an ITR intake will bolt right up to a B16 head.
Old Sep 3, 2001 | 09:58 AM
Suprdave's Avatar
Skunk 2 Manifold is a copy of the Type R Manifold for the B18C1.
The Bolt Holes are different.
With a B16a, you would use a Type R Manifold
On a B18C1, It would be the Skunk 2
Your Best Engine choice depends on what your looking for.
The B16a has high Rev Capabilities because of its 1.75:1 Rod\Stroke Ratio.
The Problem is it's small displacement
B16 Motors are Cheap though, anf you can basically interchance parts with a ITR.
(ITR Motors are basically B18C1 Blocks with B16A Heads on them)
Get what you want, gotta weight the Pros and Cons.
Suprdave
EgxHaTcHxGsR
Mar 22, 2019 11:35 PM
Elite2000
Jul 10, 2009 02:34 PM
bt redliner
Sep 17, 2005 07:48 PM
Racerj404
Nov 23, 2002 06:38 PM
