What size injectors?
Sushi Buffet Champion
B20 block
ITR head
ITR ECU
I/H/E
What size injectors do I need? Sorry for the noobie question, but I don't understand the size of the CC's, can someone please explain? Thanks guys.
ITR head
ITR ECU
I/H/E
With a B20Vtec, you should run at least a 310cc injector from what I've seen. That is the largest you can run on the stock ecu anyway, any bigger and you need to get a Hondata or something similar if you want to control fuel properly. Definately get larger than stock, that 2.0 liter w/ vtec demands a lot of fuel.
310cc's on my friends CRVTEC, it has high compression pistons and a ported head with CTR cams, ITR ECU and VAFC for fuel correction.. 12.6@107 full interior daily driven in his EK. Latez
for my b20vtec i am runnin stock GSR's with 60psi of fuel pressure.
the a/f guage seems to be happy for the most part.
t..
yea, under full load.
i ran it out to 8k in 3rd and 4th and the a/f was in the green.
however, i watched it on monday when i was cruising (70mph) on the interstate in 5th, the a/f was just in the red so i dont know but maybe the guage is off, but i pulled the plugs last night and they looked good...a little rich if anything.
what?
its a daily driven 89 crx if thats what you are askin about.
eg a drag race?
