WHAT IS LS VTEC???
Old Nov 17, 2009 | 11:31 AM
Tong.Y's Avatar
Default WHAT IS LS VTEC???
what is ls vtec?
sorry i'm kinda new at this, hope you dont mind
Old Nov 17, 2009 | 11:49 AM
GhostAccord's Avatar
Default Re: WHAT IS LS VTEC???
I'm not a B series guy. But I'm pretty sure that it is a Non VTEC LS block with a VTEC head swapped onto it. You would probably be able to find a lot of info in the hybrid forum. It seems to be a pretty popular swap for the budget oriented small block Honda guys.
Old Nov 17, 2009 | 12:02 PM
prelude1897's Avatar
it's just a LS block with a B series VTEC head hince the name LS/VTEC aka poor mans type r
Old Nov 17, 2009 | 02:08 PM
teamjdm239's Avatar
doesnt have to be a ls block. it can be a gsr, as long as its Ls crank , and rods its considered a ls-vtec with oil squirters.
Old Nov 17, 2009 | 03:37 PM
Tong.Y's Avatar
for example will a b18b or b18a engine work with b16 vtec head?
Old Nov 17, 2009 | 04:07 PM
Tong.Y's Avatar
is it simple.. all you do is just slap on the vtec head?
Old Nov 17, 2009 | 04:17 PM
not quite that easy. I know you'll need to drill new holes for oil lines as well as getting a chipped ECU and then tuning the car. I've never had a B series motor, so I can't really tell you what all goes into the whole process.
Old Nov 17, 2009 | 06:54 PM
LS_VTECteggy's Avatar
first of all a gsr has a vtec head already so idk why you would downgrade and get an ls crank and rods and an ls/vtec is ls bottom end with a vtec head put on top. The vtec head could come from various cars such as Del Sol's, Civic Si's etc...
Old Nov 18, 2009 | 02:25 PM
teamjdm239's Avatar
what are you talking about? downgrade? you know what you are talking about? throwing in ls crank and rods would be an upgrade. more stroke.
Ls vtec isnt just a ls bottom end, it could be a gsr/type r with ls internals too.
but to the o/p yes, you must tap the head for the oil.
o/p pm me and i can explain it a little more detailed for you.
Old Dec 5, 2009 | 03:27 PM
Spoon__EG6's Avatar
Just wanna ask for confirmation... Is it true both B18B & B18A don't have VTEC head?
To put B16A or B16B or B18CR head on it, with current wiring/harness is it possible to use VTEC ECU (from B16A or B16B or B18CR) without major re-wiring job.... Any suggestion where can i read about this in more details?
Old Dec 7, 2009 | 07:14 AM
White Smoke's Avatar
i my honda
Global Mod
This thread should be very helpful. There is allot of info on these setups on this site. Give our search feature a try. Search in civic, integra, and hybrid forums.
Old Dec 7, 2009 | 01:35 PM
88Hatchy's Avatar
No. A lsvtec MUST use a LS/B18A/B18B block. A B18C block with a LS crank is a B18C block with a LS crank, it's just stroking the engine. There is no way to argue around it.
Old Dec 7, 2009 | 10:02 PM
Spoon__EG6's Avatar
Tq Tq
thapimpfromchi
Oct 17, 2005 07:34 PM
helpmeplease
Oct 29, 2004 11:31 PM
shinji666
Aug 20, 2004 12:22 AM
EvilIntegrationLS
Apr 19, 2003 05:24 PM
IntegRACER
Jan 15, 2003 02:30 PM
