what harness to use?
Old Jan 31, 2013 | 02:54 PM
DawgC2's Avatar
Default what harness to use?
i am dropping a obd1 itr swap with a obd1 ecu into a 96 honda dx non vtec. is a civic ex or si harness and a obd2 to obd1 jumper harness all i need to get??
Old Feb 1, 2013 | 12:57 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: what harness to use?
There is no OBD1 ITR engine they're all OBD2. That being said if you want to use a EX harness find one from a 96-98 only. You'll need an OBD2A to OBD1 ECU adapter as well (not sure what ecu it is as there is no OBD1 ITR ECU). Even with that engine harness you'll still need to adapt your intake air temp sensor to fit into your intake arm as the ITR uses a different style sensor. Everything else should plug and play.
PabloM
Sep 29, 2013 05:37 AM
DomkeBoy
Aug 10, 2012 07:58 PM
myEK=slow
11
Aug 21, 2006 08:20 PM
TURBOED-TEG
Sep 14, 2002 02:28 PM
