VTEC solenoid's....
Old Jan 22, 2004 | 08:23 PM
Combustion Contraption's Avatar
Default VTEC solenoid's....
are all VTEC solenoids the same? The reason is, my swap is up and running, FINALLY, but when assembling the motor the VTEC solenoid from the GSR head (OBD2) had a different connector than the one of my d15z1 (VX) motor. so i had 2 choices. Use the GSR solenoid and solder in the VX connector, or just pop the VX solenoid on there. I chose the last one. The VX solenoid is much smaller though. Will it work just the same?
Old Jan 22, 2004 | 09:45 PM
bump for something i need to know...
Old Jan 23, 2004 | 10:31 AM
anyone?
Old Jan 23, 2004 | 10:35 AM
hondaZvic's Avatar
Default Re: (LsVtec92Hatch)
i dont know.. i know some mounting holes are different from some cars to others.. however.. it should work the same... i dont see why it wouldnt work the same...
u said u put it on there already? how is it? any difference?
Old Jan 23, 2004 | 08:56 PM
It bolts right up, but the actual SIZE of the solenoid is different. the one off the vx is smaller.
Old Jan 25, 2004 | 07:02 PM
Old Jan 25, 2004 | 09:36 PM
Devlins 91LS's Avatar
all b-series are the same
all d-series are the same
all h-series are the same
But they're different from each other SLIGHTLY...only the size of the vtec solenoid if i'm not mistaken
Old Jan 26, 2004 | 07:49 AM
so will it work or do i have more soldering to do? (forgive me, i dont quite understand hoq a solenoid works)
Old Jan 26, 2004 | 08:12 AM
Well, you can either solder the gsr solenoid to whatever harness you're using right now, or just use the old solenoid on the gsr head
Old Jan 26, 2004 | 10:09 AM
im using the old solenoid on the GSR head but im not far enough into my break in to even think about revving high enough to engage VTEC. thanks..
LudeToAHatch
Jan 29, 2013 03:46 AM
thatnikkashoD
Oct 31, 2007 07:46 AM
92rps13
Jan 23, 2005 11:59 AM
jonesin4abeer
14
Sep 23, 2003 07:16 AM
Quik Chris
Jan 11, 2003 01:35 PM
