VTEC problem, or so i think?
Old Jan 17, 2002 | 06:07 AM
hybrider's Avatar
Default VTEC problem, or so i think?
i was riding in my friends GS-R and vtec turn over at 4,4000rpm where it should be correct? his is stock, now thing ishe usually shifts at 7,500rpm, anything higher and will hit rev limiter
on my hybrid also a`95 powerplant, my vtec crossover is at 4.7 - 4.8k rpms, and i can take it all the way to 8,200 before it bogs......we are both using the stock p72 ecu also
is there a problem with either one? or is it just me?
[Modified by hybrider93, 7:13 AM 1/17/2002]
Old Jan 17, 2002 | 07:23 AM
Spade's Avatar
Default Re: VTEC problem, or so i think? (hybrider93)
His tach is probably off.
Old Jan 17, 2002 | 08:41 AM
hybrider's Avatar
Default Re: VTEC problem, or so i think? (Spade)
could that be the problem?
Old Jan 17, 2002 | 09:13 AM
Jackson's Avatar
should be 4400rpm vtec and 8000rpm redline.
Old Jan 17, 2002 | 09:22 AM
Spade's Avatar
If he is running the stock ECU then it will cut the fuel at redline......rev it to fuel cut off and watch the tach. FIRST check the ECU code and make sure it is what it is supposed to be.
Old Jan 17, 2002 | 10:53 AM
hybrider's Avatar
should i be worried if my vtec crossover happens at 4.7 instead of the 4.4?
Old Jan 17, 2002 | 10:57 AM
Jackson's Avatar
does your ecu say p72 on it?
Old Jan 17, 2002 | 11:04 AM
hybrider's Avatar
Default Re: VTEC problem, or so i think? (Jackson)
yes it does...........
error2k
Mar 3, 2010 12:47 PM
CarverGSR
Apr 26, 2008 12:16 PM
ImPuLsIvE
Sep 18, 2007 08:16 PM
Nyquil_Accord
Sep 28, 2004 09:36 PM
hybrider
Jan 17, 2002 11:30 AM
